Timing and Dwell...
Discussion in 'Technical' started by Shoestring, Jul 30, 2005.
  1. Shoestring
    Shoestring Member
    EL Reno, Oklahoma
    '74 Maverick
    First off: Hello all. This is my first post.
    I have a 1974 Maverick, 250 Motor. And I can't find the right Timing and Dwell. Does anyone know what they are?
    Thank you for the halp and advice. Take care!
  2. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    I'm sure one of our many 250 c.i. guys (and others) can help you when they see your post, but in the meantime, you might wanna peruse over to www.FordSix.com. Looks like they have some good information (on your engine).
    and :Welcome:
  3. lngroller
    lngroller Member
    Richmond VA
    74 Comet 2dr 250
    74 Mav 250 I6
    49 states
    Dwell 33-39 point gap .027 timing 6 BTDC
    CA Breakerless so no dwell timing same as above all same manual or AT
  4. Shoestring
    Shoestring Member
    EL Reno, Oklahoma
    '74 Maverick
    Thanks a lot guys. I'll be sure to stick around for the problems I'll have in the coming mo. to come, and to offer any advice/help I can give.
    Thanks again. Take care! :wave:
  5. Jamie Miles
    Alto, GA
    I've had a few
    My advice? Get rid of the points and go with either the Pertronix or the Duraspark II ignition. :)
  6. Mavaholic
    Set dwell first, then timming. First chance you get, convert to electronic ignition as Jamie suggested. Both are good choices. The Pertronix is the easiest.
