Transmission Leak
Discussion in 'General Maverick/Comet' started by DocRoche, Nov 26, 2015.
  1. DocRoche
    DocRoche Member
    1973 Ford Maverick
    Pulled my Maverick out of the garage yesterday and noticed a small puddle of transmission fluid on the ground. Didn't have time to really investigate it and am planning on doing that this weekend. Any common things I should look for or areas to check? I assume the pan gasket is one and iImay replace it anyway. Should iI replace the screws as well? Thanks guys.
  2. 71Mavrk
    71Mavrk Member
    Nevada
    The O rings around the shifter lever are a common culprit.
    Micah
  3. Craig Selvey
    No need to replace the bolts. You can reuse those.
  4. 71gold
    sometimes the converter will drain down and it will leak at the rear yoke seal if it has been sitting for a long time.
    NCFatBoy likes this.
  5. Hotrock
    Munroe Falls, Ohio
    First-things-first, before you move the car determine the general location of the leak from the trans. based on the location of the puddle on the floor.
    Krazy Comet and NCFatBoy like this.
  6. DocRoche
    DocRoche Member
    1973 Ford Maverick
    Thanks for the advice. It does seem to slowly drip from the pan. The underneath seems wet as well. I haven't gotten a manual yet to be able to better specify parts. But there seems to be a drip from here as well. Also starting to drip oil from the oil pan bolts so I will eventually replace that gasket as well.
  7. Rasit
    Rasit Member
    SE Pennsylvania
    If you really want to know the source of a leak, you have to clean everything up first. Big leaks are obvious but the small ones are often hard to find. Sometimes putting baby powder or flour all around the (cleaned) suspect area will quickly pinpoint the source. I have heard there is also some type of spray available that does the same thing.
  8. Krazy Comet
    Dismal Swamp
    As already mentioned by 71Marvk, that's the shift lever shaft seal...
  9. 71gold
    that's because they are the lowest point the oil can run before it drips, doesn't mean they are leaking. when you drop the pan look for a "plastic lollipop".
  10. DocRoche
    DocRoche Member
    1973 Ford Maverick
    240816-A__ra_p.jpg Thanks for the help. I looked for O-rings for the shift lever shaft seal but couldn't find them. Any recommendations of who might have them? I didn't see them at Melvins website. Rock Auto has this part as the shift shaft seal. Is this what I'm looking for?
  11. 71gold
    if it's about the size of a nickle...
  12. DocRoche
    DocRoche Member
    1973 Ford Maverick
    Wow, that's small. I'll have to research that a bit so I don't buy the wrong thing. How many do I need? Just 1?
  13. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Doc, there are actually two things you will probably need if the leak is coming from the lever. One is the seal you posted above. You will have to remove the pan in order to get the shift lever out of the case. Then pry out the old seal and carefully hammer in the new one. The o-ring you need is where the kick down lever goes through the center of the shift lever. I have done this twice on 2 different C4's. Both times I ordered the 2 together off ebay. Just as a side note, I also replaced the stock steel pan with an aluminum one. The aluminum pan has a much thicker and rigid lip that prevents it from getting distorted and provides a smooth surface for the gasket, plus it has a drain plug.
    Ronald Hopkins and 71gold like this.
  14. Ronald Hopkins
    Ronald Hopkins Member
    Morristown Tennessee
    1972 Comet GT
    Just installed a new aluminum transmission pan on my Comet it holds an extra quart of oil and has a thicker flange also has a drain plug. I could never get the stock pan to stop leaking. Seals good now no leaks.
  15. DocRoche
    DocRoche Member
    1973 Ford Maverick
    Where did you get your pan from?
