v8 wont fire now
Discussion in 'Technical' started by BrianB, Jan 11, 2011.
  1. BrianB
    BrianB Member
    1973 Maverick
    ok i tested the voltage and im only getting 7.. what does that mean?
  2. BrianB
    BrianB Member
    1973 Maverick
    also there is a wire under the dash with white peice and a little brass end inside is this the resistor wire? because that peice broke and the wire isnt together now
  3. 302-72-mav
    302-72-mav Member
    sactown CA
    this may sound dumb but do you have the battery hooked up backwards ?
    why i ask this is because i barrowed a bat from a friend and just put it in as if it was my old battery but the post's wer swaped around and i put it on - to the + side and the + side on the - side
    and yes it wuold kick over and when i would stop kicking it over it would sound like it wanted to fire up
    long story short i bought the power fire dist insted of buying a new petronix kit:mad:
  4. BrianB
    BrianB Member
    1973 Maverick
    haha nope positive is on positive
  5. BrianB
    BrianB Member
    1973 Maverick
    do you have to have a ballast resistor for pertronix? and will any coil do? or do i need a performance coil
  6. 71gold
    full 12Vs...no ballast resistor
    any coil will do...some people do use a...performance coil.
    i don't understand the problems you are having...
    ...bolt in the plate...set air gap...hook up wires correctly...:thumbs2:
    did you remove the dist?
    ...:Handshake...
  7. yellow75
    Tillamook Oregon
    You may have a bad ignition switch on the steering column, try hot wiring the the car. Run a wire from positive terminal of battery and hook it to positive on coil then use a jumper wire and jump from positive post on starter solenoid to little post on the side that the starter wire from switch goes to, I believe it is the wire closest to the front of the car.
    Make sure car is in park
    Hope this helps
  8. RobbieG.
    RobbieG. Member
    Phoenix Az.
    75 Maverick, 72 Maverick sprint, 67 Mustang bracket car, 02 F250 4X4
    You have to pull out the ballest or run a new wire. 7 is to low.
  9. BrianB
    BrianB Member
    1973 Maverick
    nope i left the distributer in and followed the instructions exactly, i watched the video on youtube for it as well..
  10. BrianB
    BrianB Member
    1973 Maverick
    the pertronix started working but only 3 of the plugs got spark! put the points back in and she started right up..defective modual?
