Visual difference in 302 vs 347?
Discussion in 'Technical' started by ResidentEvilRoc, Feb 24, 2013.
  1. junrai
    junrai Member
    rancho cordova ca
    so for about $700 total investment you got a running engine with those goodies?
    THATS A DEAL
  2. ResidentEvilRoc
    ResidentEvilRoc Got bit by the HP bug.
    Rogersville, TN
    1973 Ford Maverick
    Well, actually, I only had $100 in the Marlin. LOL.
    Yeah, the main thing I wanted was the v8 for my current '73 project. Everything else that came with it is just extra stuff.
  3. baddad457
    You beat me to it. A Marlin 22 is about worth that...........tops. It wasn't that long ago that you could buy em new from the local Walmart for $150. You stole that car. I'm gonna have to report you.................LOLOLOLOL
  4. ResidentEvilRoc
    Rogersville, TN
    1973 Ford Maverick
    LMAO!! That cracked me up.
  5. igoback70
    igoback70 Member
    IN
    70 Maverick
    Not sure if you bought the car yet or not, but one sure fire way to tell if its a stroker is to pull the pan and see if the inner cylinder walls have been beveled at the bottom, if that hasn't been done to the block it's not a stroker.
    Hey my motor is in that .01%, at least they appear to just be stock cast heads. ;)
  6. ResidentEvilRoc
    Rogersville, TN
    1973 Ford Maverick
    I should be able to take a plug out this weekend and do some measuring. Maybe I'll get more lucky and it be a 347.
  7. igoback70
    igoback70 Member
    IN
    70 Maverick
    What if it has pop ups ?
  8. bmcdaniel
    Some stroker rods that use cap screws don't need to have the cylinders clearanced.
  9. igoback70
    igoback70 Member
    IN
    70 Maverick
    I didnt think anyone made 7/16 cap bolts for 347, learn somethin new everyday, my bolts are 3/8 which is exactlly why i had to bevel the block and it's only a 331 set up.
  10. igoback70
    igoback70 Member
    IN
    70 Maverick
    Now what if his motor has pop ups, can it throw off the measurement ?
  11. igoback70
    igoback70 Member
    IN
    70 Maverick
    Sorry that was bass ackwards, the 5/16 cap bolt would be smaller correct ? Forgive me i'm a lil tired.
  12. baddad457
    No, the piston tops have nothing to do with measuring the stroke. The dome will be there at the top and bottom of the stroke. They don't disappear in between.
  13. igoback70
    igoback70 Member
    IN
    70 Maverick
    I understand that, but if the top is taller than say a stock flatop, making the distance from the wrist pin to top of the piston greater on the pop up, could that not throw the measurement off ?
  14. Krazy Comet
    Dismal Swamp
    The way it should be measured is at TDC, then again at BDC... The added length to the 1st measurement is the actual stroke, 3" for a 302, 3.4" 347 & 3.25" if it's a 331...
  15. igoback70
    igoback70 Member
    IN
    70 Maverick
    Basicly what im getting at is when the flat top piston is bottomed out the measurement will be greater than a pop up piston, yes or no ?
