Welding Tips & Tricks Needed
Discussion in 'Tool & Shop Talk' started by ATOMonkey, Mar 17, 2008.
  1. Wantamav
    Wantamav Located in Macomb Mi.
    Michigan
    '71 2 door
    Did you switch the polarity of the welder when you went from flux core to MIG?
  2. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    +1! Gas requires NEG polarity, fluxcore requires POS polarity...
    Russ
  3. PaulS
    RASelkirk,
    You should be more specific. When you say negative polarity is that the ground or torch polarity?
  4. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Sorry, electrode not ground. Here's the pic that came with my Millermatic...
    Russ
  5. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    Yes, I switched poles.
  6. das351965
    das351965 Member
    sc
    2-71 mav 1-71 grabber and 75 4dr parts car
    looks like the metal needs to be cleaner and make sure where you ground is just as clean
  7. jamestyrone
    jamestyrone Member
    Napoleon, Ohio
    1977 Comet
    If all else fails try a sieries of tacks connecting one to antother to form a bead. It's much easier to not burn through and is just as strong as a bead when mending thinner metals like body panels. Also tune in your welder by sound, it should sound like bacon sizzling(steady and smooth) when it's tuned in. Good luck...
  8. texasjack
    texasjack Member
    Aledo, TEXAS
    1975 Mavrick 4 door
    Welding
    ATO
    You did not state what kind of helmet you are using.
    I have been welding since circa 1954 and the best helmet I have ever used is the photo sense helmet.
    They are great because you can see what and where you are welding prior to the flash.
    If you are using just an old shade glass helmet you are at a disadvantage.
    Texasjack
  9. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
