What would you pay for a leaking carb.
Discussion in 'Technical' started by justin has a 74, Jan 3, 2010.
  1. justin has a 74
    kentucky
    Trans am buddy let me test out an edelbrock 750 (he got it in a deal and never tried it) and found out it leaks.
    I dont know why i want it but how much should i offer him?
    Only plan on resale or trade so ill put new gaskets on it.
  2. scooper77515
    Where does it leak from?
    How new is it?
    Pictures?
  3. justin has a 74
    kentucky
    leaks from top
    i dont know how new it is but looks like a good carb, its number is 1406
    Ill get pics later.
  4. scooper77515
    1406 is 600 cfm with electric choke. Still a good carb for your setup. Easy to rebuild.
    They go new for about $250.
    --correction, JEGS now sells them for $275.
    And "at the top" where?
    I sold mine to Bowstick, for $100, If I remember correctly, with a full calibration kit. It ran great, but it leaned out on me when I started to add on to my engine with bigger cam and heads. Double pumper corrected that, but I lost mpgs in the process.
  5. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    $10.00 Really isnt worth much if you cant fix it.
  6. justin has a 74
    kentucky
    Woops sorry their scooper, its 1407.
    And at the top where all them screws are.
  7. scooper77515
    Where the screws hold the top half onto the body?
    If so, that is most likely just a gasket swap. Sounds like someone got into it to swap some jets and messed up the gasket.
    If it is set up like the 1406, you can swap metering rods with one screw holding a plate down, 2 each on top. You can rich and lean it a bit that way.
    Further adjustments require taking the top half off and swapping out jets. If that gasket was sticky, it was likely broken, and previous tuner thought he could just stick it back together with a broken gasket.
    But without knowing this for sure, you are taking a risk of buying a nice carb with a minor problem, or possibly a piece of junk.
    Will he let you fix it up before you buy it?
  8. justin has a 74
    kentucky
    ill talk to him tonight, should beable to snag it for 10 bucks or so.
  9. scooper77515
    If he is willing to give it to you for $10, then no matter what shape it is in, it will at least be good for parts later, or to experiment with and learn about the edelbrock carbs. While you are tinkering with it, you will learn how all the adjustments work and how to tune on it, as well as how to rebuild and clean it.
    Sounds like it may be worth more than that, but I won't tell him ;)
  10. justin has a 74
    kentucky
    Yeh, he wants 30 for it so ill look into if i just need that 1 gasket and go from their, i dont NEED it.
  11. mean_maverick
    rebuild/gasket kits for them are $50+ so keep that in mind...
  12. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    Even at $30 it may be a good buy.
    Remove the top, see if the gasket is broken. If it is, that is most likely your problem.
    ::edit::
    Forgot you were buying to resell it, so I'm assuming you want a profit (duh)
    Having $80 in it won't make you much profit, but it would give you a learning experience
  13. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    for a resell, I think it`s cutting close on making money. Most guys buy a usaed carb sorta expect it may need A kit or may leak. Experence of the rebuild may be worth it, you wont get to see how it works unless buyer has you tune it. Good Luck
  14. bmcdaniel
    It's an Edelbrock, I wouldn't pay anything for it even if it didn't leak.
    That's just me, though.
  15. justin has a 74
    kentucky
    They are kind of funny looking and weird to work with, ill take a holley anyday.
