which fluid can I use?
Discussion in 'Technical' started by revatoons, Jun 3, 2011.
  1. Cowboiup1979
    Cowboiup1979 Member
    Louisville Kentucky
    1976 ford maverick 302v8
    I would NEVER use mercon V fluid in my c4, not unless it has been rebuilt, as mixing the fluids is a big concern as well.
    Here's a simple chart, from a manufacturer that shows what Mercon V is compatable with
    http://www.valvoline.com/pdf/MERCON_V.pdf
    as you can see it is completely backward compatable, with the exception of type F fluid.
    and here is the type f.... for type f ONLY scenarios
    http://www.valvoline.com/pdf/Automatic_Transmission_Type_FA.pdf
    Type F among other things, has a stronger resistance to foaming, and has a more agressive detergent package, in an oil base that has more adhesion properties than the Mercon V fluid...
    what that means to you? it better sticks and lubricates the transmissions designed for it, as well as provides proper heat transfer rates via your transmission cooler, and keeps the debris and clutch dust from building up inside the transmission.
    This nonsense of using Mercon V in an old C4, leave it to the mustang guys who don't mind rebuilding their trans every couple of years.
  2. revatoons
    revatoons Member
    Venezuela
    Maverick 74
    I rebuilt my c4 five years ago, I have since used Dexron II because here nobody sell Type F, but i need a better oil for my c4 and my power steering, I can find DII DIII and Mercon V only
  3. Ronald Hopkins
    Ronald Hopkins Member
    Morristown Tennessee
    1972 Comet GT
    I had my transmission rebuilt 3 Years age. Although it is not a daily driver. The guy that built it for me said to use mercon v. He builds transmissions for Drag cars, pulling truck, rock crawlers etc. He guarented it as long as I own the car. I have never had a problem with it over heating the transmission. So i guess it would work.
