Why is it Dying... Part 3!!!
Discussion in 'Technical' started by Mav Rick, Apr 16, 2005.
  1. FoMoDave
    FoMoDave Maverick Owner
    Cumming Ga.
    1973 Maverick 302 c-4,1971 Maverick 6cyl
    Yep - what yellow 72 said . But I'm not sure wich term. to hook it to. Anyone out there know? Hope that is it.
  2. Mav Rick
    Mav Rick Member
    St. Petersburg, FL
    1971 Grabber
    Yeah, if someone could let me know, that would be a HUGE help. Thanks!
  3. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Basically it needs to be a hot when switch is on. If you want to run a wire to your fusebox you could come off the wipers, fan, radio fuses. Or you could probe wires and connections under the hood while switch is on. I would go to the fusebox. If you do go to the fusebox go to the dead side of the fuse for fused protection of your new circuit. If you dont know what the dead side is, it is the side that will not carry juice if the fuse blows, usually the right side of the clips that hold the fuse.
    Dan
  4. Mav Rick
    Mav Rick Member
    St. Petersburg, FL
    1971 Grabber
    My fuses arent labled anymore. does anyone know which fuse is for the radio/fan/wipers?
    Thanks Dan, I think Ill do that unless anyone else has some other ideas... heck, ill try anything right now!
  5. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Upper right corner - Radio
    Lower right - heater
    I wipers are protected by a circuit breaker on the switch
  6. Mav Rick
    Mav Rick Member
    St. Petersburg, FL
    1971 Grabber
    Thanks for your help!
    Ill work on this over the weekend.
