Would 2-1/2" siamesed exhaust be enough flow for my setup?
Discussion in 'Technical' started by scooper77515, Apr 6, 2011.
  1. scooper77515
    Bryant, that is why I was thinking of capping off one side of my exhaust right at the downturn. I figured it would act the same way, go through the flowmaster, back to the H-pipe, then out the other side to exhaust.
  2. Bryant
    i would worry about how that method will created different back pressures for each side of the motor. im sure it will run but i suspect could creat a vibration from half the motor being choked down.
  3. kyle1972
    kyle1972 Member
    Modesto California
    1972 4 door Maverick 250 I6
    im just curious, but has anybody just thought of switching to different series of mufflers? if yer running flow masters that is....
  4. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    My truck drowned so bad I stopped driving it. Then I got bored and cut the pipe at the muffler. and just tried different length pipes until it went away. It runs out just in front of the rear tire like lightnings do. It started when I had I a new flowmaster installed and put it about a foot closer to the engine than the flowmaster he replaced,same size and series.
  5. cyclonewill
    cyclonewill Member
    SandSprings, Oklahoma
    Flowmasters = drone.
    I tried running tailpipes when I got my 89 5.0, it didn't help the drone. If anything it moved the noise out from under the car, but would still drive me crazy at light throttle, about 2,000rpm. Got rid of the flowmasters, welded in hookers, and it still rumbles, but no drone.
  6. scooper77515
    yes, new mufflers. I got you guys. But not until I experiment with the ones I have.
    Wouldn't take me 20 minutes to cut these off and weld in some others, but that takes all the fun out of playing Mr. Scientist!
    If I didn't want to experiment with the car, it would have been done and painted about 4 years ago!
  7. scooper77515
    OK...on my drive to work today, I decide that if this little experiment doesn't work, I will just cut the 44s out and stick in a couple 18" glasspacks.
    I always liked the sound of 'packs...
  8. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    I really like this idea! It's like the 'old school' method of sound cancellation :clap:
